Online shopping is currently unavailable.
Please contact us for help or try again later.
NI TestStand
Data logging stopped
Our test station saved data in .mdb files at one time. I just checked and it hasn't updated for several weeks. It appears to have stopped after a new deployment. Under database options Disable Database Logging is  unchecked. The Data Link is Access with a connection string of:
 "Provider=Microsoft.Jet.OLEDB.4.0;Persist Security Info=False;Data Source=C:\\Documents and Settings\\All Users\\Documents\\National Instruments\\TestStand 4.2.1\\Components\\Models\\TestStand Results.mdb;".
What should I do to turn it on?
thanks,
jhite
(3,591 Views)
Check the 'DatabaseOptions' callback within your Process Model.  Perhaps you or someone else modified various options.
Normally these are in the form: Parameters.DatabaseOptions
Check to make sure Database Logging is enabled:  Parameters.DatabaseOptions.DisableDatabaseLogging = True
Paul H
(3,585 Views)
What are the changes done to the system by the new deployment?
Do you get a textual report?
Norbert
Norbert
Expert: Geometry
(3,582 Views)
