07-10-2012 12:32 PM
I customized my toolbar to add the run as seen in the attached image. When I close TestStand and re-open, it is no longer there. How do I get this customized toolbar to maintain its settings?
I also tried to use rearrange icons and add that button to the Debug Menu Bar, but that didn't work either.
07-11-2012 10:42 AM
I am using TestStand 2010 SP1 and was able to add a Second Execution Entry Point by following the directions here. Then when I close TestStand and open it again, the button I added is still there. What version of TestStand are you using? I am assuming you are making this change in the Sequence Editor.
07-11-2012 10:44 AM
Lock your UI configuration in the View menu
07-12-2012 07:25 AM
It was my saved UI configuration since I use a custom UI configuration, I had to save it with the added button on there.
07-16-2012 11:43 AM
To clarify for other readers. There is a setting in the sequence editor options dialog to always load a UI configuration at startup (rather than restore the settings you had when you last exited). He was likely using this setting.
-Doug
