NI TestStand
Custom step type Export and Import
   I have created custom step types similar IVI for all my HAL drivers.
I need help in sharing it with my team in different locations.
I am looking at exporting and importing of the custome step types similar to templates.
Could anyone help me with this.
Thanks in advance
Anna
(5,956 Views)
Anna,
when creating the step type definition, you have picked a location for it. By default, it is "MyTypes.ini".
You can create your own custom ini-file containing your specific step types in the type editor.
When distributing your step types, you have to pass the ini-file containing the type definition(s) AND all sources connected to that types (substep modules).
On the target machine, you have to include that ini-file in the system for type definitions in the type editor.
Norbert
Norbert
Expert: Geometry
(5,929 Views)
Hi Nobert_B
Thaks a lot tried it...
It worked...
Anna
(5,921 Views)
Furthermore, if you put the type palette file in the <TestStandPublic>\Components\TypePalettes directory on your target machines, it will automatically be loaded the next time that version of TestStand is run on that machine. You could also put these files in source control so that whenever a developer does a "get" on the files, they will automatically get the latest version of your step types.
-Doug
(5,916 Views)
Thanks Doug.. Tried that... This is easy...
(5,894 Views)
