NI TestStand
Custom User Interface - How to use native string control to trigger each test and pass serial number
Picture 1
Picture 2
This is the one Custom User Interface which I modify from one demo, now, what I want is don't show the message box (picture 2) , just use the string control ( show "11111111" & "22222222" on the picture 2) to check the serial number length and  trigger each test separately, and also pass each serial number to teststand variable, thanks!
(5,346 Views)
Not sure if I undarstand correctlly but if you don't whant to display your UUT Information widnow (picture 2), than you need to overwrite Pre Batch Callback (if you use Batch Model) in your sequence. Use your custom window (from picture 1). In sequence use Parameters.ModelData.TestSockets[Locals.Index].UUT.SerialNumber to store your serial number. Before you pass this data you could check it with, for instance, with Len() function in some Statement step. Batch Process Model will control each socket separately.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(5,317 Views)
Yes, I don't want to show the picture 2, thanks for your suggestion, Is threre some demos to show the details for that? thanks!
(5,278 Views)
Check those examples:
http://zone.ni.com/reference/en-XX/help/370052N-01/tsexamples/infotopics/multiuut/
http://zone.ni.com/reference/en-XX/help/370052N-01/tsexamples/infotopics/process_model_preuut_postuu...
http://zone.ni.com/reference/en-XX/help/370052N-01/tsexamples/infotopics/process_model_prebatch_post...
Michał Bieńkowski
CLA, CTA, CPI
(5,274 Views)
Although I want to find a specific demo, but there are still some help, thank you all the same.
(5,253 Views)
Hi, from where did you get Teststand user interface Demo that you modified!
(4,114 Views)
Hello , I am trying to load and run  the Teststand sequence in LabVIEW Native Controls . Could you share the source code. Thanks
(2,860 Views)
