NI TestStand
Current Sequence Status
Is it possible to check the status of the current seqeunce during main execution or just in cleanup.
I was hoping to set a precondition for my steps in main that if execution has errored or failed do not execute the step -  I suppose on fail I am aswell just jump to cleanup..
Shane.
(5,122 Views)
Hi Shane
Try using ThisContext.RunState.SequenceFailed to check the status of your sequence.
If some of your steps has been failed i would think on a PostAction to jump to clean up
Hope this helps
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(5,105 Views)
There is also a global setting (station options dialog at the bottom of the first page) to goto cleanup on failures.
-Doug
(5,093 Views)
Thanks for the replies.
I tried ThisContext.RunState.SequenceFailed  but it doesn't seem to update until cleanup.
Also I only want certain steps to jump to cleanup so I don't want to use a global setting.
I have posted another post on trying to jump to cleanup using the property loader - I can't seem to get the syntax correct.
http://forums.ni.com/ni/board/message?board.id=330&message.id=28162#M28162
Maybe one of you guys can help with this?
Thanks & Regards,
Shane.
(5,075 Views)
Hi Shane,
I have re-tried RunState.SequenceFailed on my TS 4.0 maschine in an example
and it is working a suspected. It is updated once a step has been failed!
Note: All steps has been set on default as Step Failure cause Sequnce Failure. This should not be disabled, of course!
In your case i would use the step post action and jump on fail to cleanup.
Just take a look on the example.
Hope this helps
juergen
--Signature--
(5,067 Views)
Thanks for the example sequence file - it ran as you outlined - I must have had something wrong with my implementation when I tried it out. I will look at this again.
Thanks & Regards,
Shane.
(5,044 Views)
