NI TestStand
Create indentation programatically in report file?
Hello community,
From time to time it would be nice to indent a given step in the report. I could surround it with a for loop or so, but I am wondering if there is a more elegant way to do it?
thanks.
(3,638 Views)
Are you just looking to customize the appearance of the report? Let us know exactly what you want so the community can provide some possible solutions.
Michael B.
(3,608 Views)
Hey Michael,
If I have a step in a for loop executing lets say 5 times, then it appears in the report 5 times and all these 5 entries are indented. The more nested loops I have the more indentation I get in the report for a given step.
In the sequence I work on at this moment I dont use any nesting, but for some tests it would be nice if they would show up in the report indented. It would increase the readibility of the report a lot.
Is there a way to programatically achieve this, or do I really need to put a for loop around the step? This latter solution would be pointless in the sense that it makes my sequnce look more complicated than it is really.
Thanks.
(3,600 Views)
The easiest way to improve readability of your reports is to change the style sheet in the Report Options window. Navigate to Configure » Result Processing to launch the Report Options dialog, then select the Options icon for the Report Generation plug-in. Then select the Style Sheet dropdown and select either tr5_expand.xsl or tr5_report.xsl. Both of these report styles are more readable.
Michael B.
(3,594 Views)
To figure out how to add the indents in the report can you answer the following questions:
  • What type of report are you using (ASCII, HTML, XML or ATML or another type)?
  • How exactly do you want it indented? Do you want each step on alternating indent levels to separate them? Do you want each step indented or just some?
Michael B.
(3,589 Views)
I'm using the built-in "expand.xsl" stylesheet to generate my xml reports.
As I have described above, I'm looking for a way to indent some of my steps programatically.
thx.
(3,583 Views)
It looks like to implement the functionality you desire you will need to modify the stylesheet. Here are some resources to help you out:
How to Modify a TestStand XML Report Header
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGlBCAW&l=en-US
Customizing XML Report Style Sheets
https://www.ni.com/docs/en-US/bundle/teststand/page/customizing-xml-report-style-sheets.html
There are still other options that can be explored to make your reports more readable. Some examples could be creating a summary report, removing non essential information from the report, or modifying the background cell color based on the step.
Michael B.
(3,578 Views)
