12-04-2013 10:58 PM - edited 12-04-2013 11:01 PM
I followed the instructions at http://www.ni.com/white-paper/9923/en/ to create a TestStand deployment. Step #3 says to set my Adapter to the LabVIEW RTE, which I did.
Unfortunately, TestStand is now unable to find the VIs in user.lib. My test sequence works fine when I use the LabVIEW Development System instead of the RTE.
What's the correct way to tell TestStand where to look?
Other notes:
Thanks!
12-06-2013 09:56 AM
Hi JKSH,
When you say it’s can’t find the VIs in user.lib, where do you see the problem? Does it give you an error message when building the deployment, when it actually deploys, or are you just unable to add the files to the deployment? Do you get a particular error code or message?
Kelsey Johnson
Applications Engineer
