NI TestStand
Control PWM Fan with NI DAQmx and Matlab DAQ tool
Hi all,
I´m a freshman with NI and need some help. I have a PWM-fan (DC, datasheet below) that I want to control with MATLAB DAQ tool box using NI DAQmx. The fan itself has 4 cables: +, -, sensor and PWM. I connected the + and - to an external voltage source (24 V, max. 3 A).
In my NI DAQmx chassis there are boxes of NI 9213, NI 9216, NI 9219, NI 9263, NI 9239 and NI 9481.
The sensor cable I connected to the NI 9239 (positive channel) as it is an analog input card. In Matlab I set it to "voltage" but I´m not sure if this is right. To the corresponding negative channel I connected te mass (-) that I split from the voltage source.
Without connecting the PWM cable I get a signal from the fan through the sensor cable that looks like the picture in the appendix. When I change the voltage in the voltage source, the signal changes. So that´s a good sign aI guess.
My first question is: what do I see in the graph? - Is it a voltage / current / ... ? Or am I wrong and used a wrong NI card (maybe it has to be a digital input card?
Further, how do I connect the PWM cable? Just the one cable to a digital output (that I don´t have yet?)? Or is there a way to connect it to a analog input?
Do you have any code ideas how to control  the fan with PWM signal in matlab?
Any help would be so great!
Thanks and regards,
Hanna
(293 Views)
(292 Views)
You might try to post your question to an appropriate forum like https://forums.ni.com/t5/Multifunction-DAQ/bd-p/250
(226 Views)
Accepted by Hanna_24
Thanks, I could solve the  problem.
(221 Views)
