We are using an activex method call to open an object reference to a step and programatically rename it. This is done many many times during our test run, thousands. We ran into an "out of memory" problem we had never seen before during a 72 hour test run, and in hunting down any possible memory leaks, I am wondering if a corresponding close is needed for the step reference open we are doing, and how. I have hunted around the different methods/properties, and can't seem to find if there is a step reference close. I have attached the specify module screen of the activex call which opens the step reference.
Thanks for any replies
David Jenkinson
Message Edited by david_jenkinson on 06-11-2007 05:07 PM
