NI TestStand
Clone Variables (Locals and FileGlobals)
Hi !
Is it possible to clone variables ?
I found the way to use the clone method with steps, but I can't find the way to do it with variables.
What I did is get the reference onto the 'Locals' in sequence (the reference is a PropertyObject). Then cloned this PO using the Clone method, which returns a reference on the cloned Object.
I have the reference of a sequence in another sequence file, in which I want to copy my variable. But I can't find any method from the Sequence class which would allow to add the cloned variables using the clone refrence.
Any idea ?
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(4,717 Views)
I found a solution using the cast AsPropertyObject and inserting SubProperties with the correct lookup strings !
(4,709 Views)
Clone is possible,
Just see these threads, there were some examples
http://forums.ni.com/t5/NI-TestStand/Repeating-a-Failed-Sequence-once-more/m-p/1042268/highlight/tru...
http://forums.ni.com/t5/NI-TestStand/Copy-result-container-why-do-I-get-a-property-types-do-not-matc...
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(4,699 Views)
