NI TestStand
Citrix DOORS 9.2 Client integration with Requirements Gateway - 'Error: Conversion problem (License error (feature ) NIRG_DOORS)'
What do I need in order to connect to my DOORS 9.2 database with the Requirements Gateway, while I'm using a Citrix web client? With the actual setup I get this error: 'Error: Conversion problem  (License error (feature 😞 NIRG_DOORS)'
Thank you,
Teodor
Message 1 of 8
(5,353 Views)
Maybe the following link might help
http://zone.ni.com/devzone/cda/tut/p/id/8417
regards
Ray
Note to NI: Why doesn't NI Gateway have its own board?
Ray
Ray Farmer
Message 2 of 8
(5,331 Views)
I think this information from the listed link works, but only with a DOORS client installed on the running computer. Using Citrix, DOORS will be executed from a web server (which requests an aditional user and password for accessing the Doors application itself), which means that Requirements Gateway cannot trust in the information stored into the Windows registry files or environment variables used to access the DOORS server.
So I'm waiting for other ideas.
Anyway I'll add a link here for the ones who uses local client solution for DOORS. Maybe it will be useful for them.
http://digital.ni.com/public.nsf/allkb/2CDF3F9B72AFADB5862574F700571557
Message 3 of 8
(5,325 Views)
teodor -
Would you mind if I asked the forum administrators to give me your email so that we can troubleshoot this further that way?
Manooch H.
Message 4 of 8
(5,312 Views)
Yes it is fine with me. You can ask for the e-mail if this information is forbiden to be written here.
Thank you,
Teodor
Message 5 of 8
(5,310 Views)
Teodor -
After looking into this further, unfortunately, NI Requirements Gateway 1.1 requires your system to have the DOORS client installed and does not support the web server interface.
I can submit a request to consider including this functionality in a future version of Requirements Gateway on your behalf.
Manooch H.
Message 6 of 8
(5,299 Views)
