NI TestStand
Changing color of skipped step on step list configuration
I'm using TestStand 4.1 and I'm trying to change the color of the skipped step on step list configuration for sequence view for better visibility. I added the line below to "Fonts and Colors" section to do that:
Step.GetRunModeEx() == "Skip" ? tsLightGray:tsBlack
It works fine if there's no Cleanup or Setup step. But when I add a Cleanup or Setup step it generates an error whenever I change the Run Mode of any step.
Here's the error I get.
Do you have any idea how can I manage that to work?
(4,219 Views)
Hi qool,
I was able to reproduce this behavior on my machine.  I have reported it to R&D (#205490) for further investigation.  Thanks for the feedback!
Cheers,
Kelly R.
(4,168 Views)
Thanks for the reply. Did you try that on TestStand 4.2.1 or 4.1?
(4,152 Views)
Hi qool,
I tested it on TestStand 4.0, 4.1 and 4.2.1.
(4,143 Views)
