NI TestStand
Changing TestStand Sequence that is loaded when pressing "File>>New Sequence File"
I want to modify the "blank" sequence file that is loaded when the user press "File>> new sequence file", so that the "new sequence" is a predefined sequence
(...in order to add some default locals, for instance).
Is it possible?
thks in advance, Zib
(3,932 Views)
Zib -
You cannot specify what sequence file is used when you select File>>New. This is a suggestion that we have heard before.
A workaround would be to add a configuration callback sequence to your model. The name of the entry point might be "Open Template" and you could specify that it is visible in the File menu. You cannot prevent the one that we display from being available though. The callback sequence could call Engine.GetSequenceFile to open a template sequence file, call PropertyObject.Clone on the sequence file ref to get a ref to an unnamed sequence file copy, and call Engine.PostUIMessage and pass "MainSequence" for the string data and the copy ref for the reference data, which will open the file in the sequence editor.
Scott Richardson
Scott Richardson
https://testeract.com
(3,932 Views)
Hello
I know this is an very old thread, but has this changed the past ~20 years? Is it possible today (TS2023) to specify what sequence file is used when you select File>>New
Thanks in advance
Bjarne
(971 Views)
Still the same to my knowledge
You might want to go with the answer Scott gave back then
(963 Views)
(939 Views)
But still... you should also be able to implement this and call the code from the Tools Menu....
(929 Views)
