NI TestStand
Change expression font size
Is there a way to change the font size of the expressions? I am working on a 24" monitors, but editing expressions still requires binoculars 🙂
thanks.
(3,199 Views)
Normal Zoom option will help you to edit (Ctrl_Scroll up)
(3,173 Views)
Ah cool... Now I see that right click on the textbox >>> options and there is a font size listbox where you can set the default font size.
It probably would have been way too complicated to implement a standard windows font dialog box... 😛
(3,171 Views)
Good!
As you wanna edit just zoom option is easy than using options, if u want by default then using options is the best way.
(3,162 Views)
