05-12-2006 04:58 AM
05-16-2006 10:13 AM
michelss,
honestly, i dont understand your problem. so here is what i understood from your posting:
you created a sequencefile called DEMO.seq which contains a sequence. this MainSequence contains to LV-Steps, one for ADD and one for MULTIPLY. you store results and input as local variables in TestStand.
Now the posting is getting very confusing. i asume that you created a new sequence (within your DEMO.seq?) using a third VI. one parameter of the VI should be a "dropdownlist" containg ADD and MULTIPLY (i think you will use an enum here?!).
another possibility is that you created a new step type (where? within the file or in the station?) which should use the EditSubStep to choose between ADD or MULTIPLY. now the possible VIs contained as module would be the VIs from the DEMO.
What is now the correct interpretation? What is the exact problem?
Norbert B.
