there's a couple of options here, and I've included what I think is the simplest below (using TestStand 2.0.1).
It's not exactly elegant though. What I've done is to put in a step that finds out the number of steps to load (based on an earlier decision - in this case a message popup step). I read a number from the limits file, and use this in the looping options of the property loader step that's loading the values into the array. I've done it with a fixed size array target here, big enough to take any incoming data. (Otherwise, knowing how many items you're going to load from the limits file, you could start with an empty array and re-size it prior to loading).
I've cheated slightly by using the pre-expression on the property loader step to specify where th
e data is coming from and where it's going to in the sequence on each iteration of the loop based on the Runstate.Loopindex.
Another option is to go straight into the property loader step, and keep loading properties until the Step.Result.NumPropertiesRead = 0 (remember we're only doing this one at a time)
Another idea would be to load in a value, and check it isn't a "flag" value (i.e. you'd never use say 999 in your array, so set the last element in your limits file to this, and drop out of the loop when this happens.
Further still, you've got the source code for the property loader step, so you could re-write it to make a custom step that loads an array until it fails all on its own (no looping in TestStand).
Hope this gets you going
S.
// it takes almost no time to rate an answer
