NI TestStand
Can a TestStand deployment built with XP run on a target machine running Windows7?
All,
I knew it would come to this eventually. My very reliable development machine is running Windows XP. I am now facing the situation of building a TestStand deployment to distribute to target machines that are running Windows7. I am trying to head off trouble and troubleshooting that may not be worth it. Will this work?
Thanks in advance for any information regarding this situation.
Troy
(2,693 Views)
Hi Troy,
You shouldn't run into trouble, but you may want to be aware of the differences in directory paths
Cheers,
KyleP
(2,670 Views)
