09-28-2015 12:30 PM
Is there a way for teststand to compare two text files without Labview? I'm doing some loop testring and I just want to check that FileA is the same as FileB and show the differences if they're not the same.
09-29-2015 05:35 AM - edited 09-29-2015 05:38 AM
you can use the .net step StepTye. and consuming TextReader class.
I assume you will need 10-12 Steps 2*(open,close,Size,Read) Compare and loop to perform this task.
Another option is using the command line from WinMerge.
http://manual.winmerge.org/Command_line.html
Regards
Juergen
