NI TestStand
Can I change values of variables in the variables view control?
I want use the variables view control in Labview. I can only see the Values, but I can not change Values or create new Variables. Is there a chance to do this?
I use Labview 8.6.1 and Teststand 4.1.1.
(3,153 Views)
Accepted by topic author T.
You need to enable editing mode for the ApplicationMgr, by setting ApplicationMgr.IsEditor to true. Note that you must have at least the custom editor license for teststand in order for this to work (otherwise it will prompt the user to activate a license with these privileges).
Hope this helps,
-Doug
(3,146 Views)
Many Thanks. Now it works.Smiley Happy
(3,120 Views)
