NI TestStand
Calling a DLL in TestStand by reference
 Greetings-
I am writing a DLL for TestStand calling, but failed to call the DLL, please kindly find the attached Doc file and help me how to fix this issue.
Many thanks-
W
(1,909 Views)
Hi W,
I've got several questions for you :
  • Why don't you call your LabVIEW VI instead of building a DLL ?
  • Why do you use a CVI step to call the built DLL ? There is DLL adapter for C-calling convention DLL calls (the icon with the red C up to a gearwheel)
CLA, CTA
View Cyril Gambini's profile on LinkedIn
(1,893 Views)
Greetings-
Thanks for your reviewing.
  • Why don't you call your LabVIEW VI instead of building a DLL ? yes,  I can call it as Labview VI,and I looked a application with DLL under TestStand, so I want learn it.
  • Why do you use a CVI step to call the built DLL ? There is DLL adapter for C-calling convention DLL calls (the icon with the red C up to a gearwheel) / I found the application is using CVi step to call a DLL under Teststand.
I tried C-calling, still failed to call the DLL.  Please kindly find the attachment and help me how to fix it, I want to call DLL under TestStand, I don't know where issue result to the failing.
Many thanks-
W
(1,887 Views)
