07-21-2005 05:35 AM
07-22-2005 11:24 AM
07-24-2005 11:43 PM
Hi Caroline,
Thank you for the reply.
The DLL, I am try to access has a few functions defined as Public and Static both. But some are not defined as static but they are defined as public. As functions defined by as Public and Static are comming in the function list. But the others are not comming. Is there any way to get this functions (Not defined as static) in the function list or other way to access it?
thanks,
regards,
vishal.
07-25-2005 01:23 PM
Vishal -
We are assuming that you are attempting to call C++ methods exposed by a DLL. TestStand can call static methods because the methods do not need an object to be created before calling them. TestStand has no way of creating a C++ object, so it cannot list the public methods on the class. If you have access to the DLL source, you could expose new static methods on the class, or you must wrap this DLL in another DLL that exposes C functions or static C++ functions that TestStand can call.
