03-02-2016 08:36 AM
I am trying to figure out if there is a way to access the sequence context of a runnning thread from a CVI Module without the sequence context reference being passed into it?
For example if I want to use a DLL module and call a function : RFGetLosses (param1,param2,¶m3) can I use sequence context within that function to access Test Stand objects without one of the parameters being a reference to Sequence Context.
I hope the question makes sense!?
Steve
03-03-2016 09:52 AM
Hi Steve! I may be misunderstanding your question, but are you asking if you can access objects within the sequence context of a separate step from inside of a CVI DLL function?
