NI TestStand
C#-OPUI: How to check that Model/SequenceFileLoad is finished?
i created a OPUI in C# where i call TestStand2012.
Now i have the problem that i need to find out when the SequenceFileLoad of the model-sequence is finished.
I cant find an event for this. (or is there a variable for this?)
How can i check in C# that it has finished?
Thanks for help
(4,039 Views)
You can either:
1) Handle the UIMessageEvent callback of the application manager and look for the end of execution UI Message, then either check if it is for the sequence file load callback you are looking for.
or
2) If you control both the sequence and the UI, just do whatever synchronization you want in the sequence and the UI. You could use a TestStand notification, or a C# event. There are many ways to do it.
Hope this helps,
-Doug
(4,030 Views)
Currently i am sending as last step in the Model-SequenceFileLoad a UserDefinedMessage.
In C# there is then a loop (in a thread) that is waiting for this Message-Number.
For your other solution:
I see the EndOfExecution but how can i know that it is coming from Model-SequenceFileLoad?
Thx
(4,013 Views)
Accepted by topic author OnlyOne
Using a user defined message seems like a good way to do it.
"I see the EndOfExecution but how can i know that it is coming from Model-SequenceFileLoad?"
The UIMessage class object has an Execution property. You can use the TestStand API to examine the execution to try to determine if it is the correct one. You could perhaps use msg.Execution.DisplayName,  msg.Execution.Id, and/or msg.Execution.SequenceFilePath to determine if the UIMessage is for the appropriate execution.
-Doug
(4,001 Views)
