NI TestStand
Batchmodel - Reuse of created resultvalues
i have a batchmodel with 5 batches.
Now there is a teststep that gets a value and calculates a new value as output. Now i want to use this new value as an input parameter of an other teststep.
1. Can i simply save the value in locals.value? Or 2. do i have to create an array locals.value[0..4] to save for each batch the value in its own variable?
If variant 1 is working.. is this also valid for the StationGlobals or only for locals?
Thx
(3,739 Views)
Locals are created per execution (per test socket in the batch case) so your option 1 (save the value in locals.value) should work.  StationGlobals are global across everything.  FileGlobals you can choose the scope as described here:
http://digital.ni.com/public.nsf/allkb/21368C716B06780A86256A5C007075DB?OpenDocument
Pulido Technologies LLC
(3,737 Views)
