06-17-2022 10:01 PM
Hi
In my hardware for best performance I have dedicated hardware for every site , meaning that they can all run in parallel , but at the end they have to sync
TestStand has batch model , but I am not sure in TestStand , it sync after each step or it is possible to sync at the end of sequence ? Definitely syncing at the end of each step is not useful for me and it waste a lot of time , because I have to always wait for slow DUT. Please help which model TestStand has as part of batch mode? is it batch step or batch sequence ?
Finally what is the model in NI STS ? is it batch step or batch sequence and is it configurable to switch between them?
06-17-2022 10:10 PM
Batch model sync at the beginning and at the end.
NI STS uses Batch model at sequence level if there are no shared instruments between sites.
06-18-2022 10:26 AM
Thanks , this is great because I have no shared resource and they can fully run in parallel and sync at start and end of sequence
I don't have TestStand and STS right now , but I remember in batch model they used to sync after each step and then go to next step and this was the default setting . Do I have to change the setting to make it sequence sync instead of step sync ?
06-18-2022 11:48 AM
No, by default, the batch model sync only at the start of batch and end of the batch and not at every step unless you configured each step for synchronization.
06-18-2022 12:42 PM
Thanks Santo, that is exactly what I want both in TS and STS. Sync at start and sync at end so all DUTs can run fully in parallel and sync at the end
