@Mr._Jim, this is basically how I also implemented the autostart feature (with the option to select execution entry point). I was closing the sequence file reference in the application shutdown state before, I tested to close it in the same place you did but the result is the same. I do have the LoadModules function in my code but that is disabled as it is causing the application to stop responding when executed (before the preloading modules dialog appears).
