NI TestStand
Automating Deployment in TestStand 2014
I am trying to automate deployment of TestStand systems using a continuous integration server, and I would like to modify deployment files (.tsd) and call the deployment utility through the command line.
I am able to build existing .tsd files by calling "C:\Program Files\...\Deployment Utility\DeploymentUtility.exe" build "C:\...\deployment.tsd", but I would also like to make modifications to deployment files.
It seems like TestStand 2016 allows you these capabilities, but I have not found similar documentation for TestStand 2014. Does anyone have any experience like this or know where I could get help for this?
(2,059 Views)
Hello Noah,
Do you perhaps mean this?
Custom commands dialog box
I found it on TestStand 2014 Help page, it looks the same as the TestStand 2016 help page, so are these the capabilities you were looking for?
Reg,
Sebastian
(2,007 Views)
Accepted by topic author noahk85
BuildTSD wasn't officially documented until 2016. Here's the original NI Labs documentation:
https://forums.ni.com/t5/NI-Labs-Toolkits/TestStand-Command-Line-Deployment-Build-Tool/ta-p/3527113
There's also a whole forum group dedicated to CI which I've posted some relevant TestStand content to:
https://forums.ni.com/t5/Continuous-Integration/Using-TestStand-and-Jenkins/gpm-p/3703537
-Trent
https://www.linkedin.com/in/trentweaver
(1,998 Views)
