NI TestStand
Automatically Replacing Absolute Paths with Paths Relative to the TestStand Search Directories
       I'm trying to replace file paths on a few projects with relative paths. I've found this  http://www.ni.com/example/25087/en/ which suggests the sequence there should do it. However I get a lot of error when I try to run this sequence.
      Anyone else encountered this issue. (I'm using teststand 2010)
      Thanks!
(4,342 Views)
Hi ds_1,
Apologies that this reply isn't massively helpful but it seems like some of the parameters are missing for certain steps in the sequence. This has likely occured due to the sequence being written in an older version of TestStand.
I would recommend posting feedback on the actual example itself requesting an updated version. The person who originally uploaded the sequence will be notified and can make the changes.
Best Regards,
Chris
National Instruments - Tech Support
(4,237 Views)
