02-24-2014 03:29 AM
I'm trying to replace file paths on a few projects with relative paths. I've found this http://www.ni.com/example/25087/en/ which suggests the sequence there should do it. However I get a lot of error when I try to run this sequence.
Anyone else encountered this issue. (I'm using teststand 2010)
Thanks!
03-11-2014 08:28 AM
Hi ds_1,
Apologies that this reply isn't massively helpful but it seems like some of the parameters are missing for certain steps in the sequence. This has likely occured due to the sequence being written in an older version of TestStand.
I would recommend posting feedback on the actual example itself requesting an updated version. The person who originally uploaded the sequence will be notified and can make the changes.
Best Regards,
Chris
