11-22-2022 03:20 PM
Hello fellow TestStand user,
I have a subVI that returns a cluster.
I call this subVI in 100+ test sequences.
The issue occurs when I decide to add a new control to the cluster.
Although I used TOOLS > Update VI Calls...> Reload Prototype if modified, I still have to go manually in every sequence and:
1. Update Custom Datatype.
2. Apply Cluster Passing Changes.
In LabVIEW if I update a subVI's output cluster, all callers are updated the next time I open them, and all I have to do is Save All, because I used a typedef.
Is there the same feature in TestStand? I takes me an hour to manually update all the calls.
Solved! Go to Solution.
11-23-2022 05:34 PM
Quick thought/idea: wrap this vi in a sequence and call it instead. Update shall be easier.
