NI TestStand
Auto schedule across multiple instance of user interface
I am trying to create a test sequence with auto schedule that would work across multiple instance of user interface.
I have tried the following,
1. Use lock name in Use Auto Scheduled Resource as "*POWER_METER". TestStand returns error
"Error executing 'Use Resource' step.
User-defined error code."
2. Use Acquired Lock in Use Auto Scheduled Resource as StationGlobals variables and lock name as "POWER_METER". TestStand does not report any error but the Auto Scheduling does not work across the user interfaces.
However, when I used "*POWER_METER" as the name in Lock step type, it worked correctly across the user interfaces.
I am using TestStand 4.0
Is there a way to make the auto scheduling work across multiple user interfaces like the other synchronization step types e.g. Lock
Thanks.
(3,884 Views)
The first question I have is why you are doing it across multiple user interfaces instead of using either the parallel or batch model?
(3,882 Views)
AutoSchedule will not work across processes. However, if you take each of your AutoSchedule blocks and transform it to a separate thread that acquires a cross-process lock, you will get a similar scheduling result, assuming you don't need to use the AutoSchedule alternative lock feature.
(3,876 Views)
