NI TestStand
Auto Login via TestStand UserInterfaces
Hello everybody,
i´m trying to login a user programmatically during the MainForm_load of the Simple Userinterface.
I tried already
axApplicationMgr.GetEngine.CurrentUser = axApplicationMgr.GetEngine.GetUser(current_user)
but this only changes the user which appear in the login window.
Is it possible to start the login process without showing those login window?
Thanks for advice.
(2,571 Views)
The login prompt is handled by the FrontEndCallBacks sequence.  You can change the behavior by following this article
Automatically Logging In all Users as Operators in Your TestStand Operator Interface - National Inst...
(2,538 Views)
You can also use this method if it suits your application ;
https://forums.ni.com/t5/Example-Code/Automatically-Create-a-TestStand-User-for-the-Windows-System/t...
Ravi
(2,524 Views)
Thank you, ee-jallen, for the link for the article. This solution is not exact what i was looking for but i will try to modifie it to login a specified user.
If i am able to find a solution, i will post it here later.
(2,513 Views)
Thank you for your advice RaviShrigiri, but our TestSystem will only have one Windows Account for all the user, so this solution don´t work for me.
(2,505 Views)
Accepted by topic author sneb898
Okay... The problem was caused, because the EXE-Call parameters were processed after the MainForm_Load, so my current_user variable was still empty.
I set the
now in the axApplicationMgr_ProcessUserCommandLineArguments(...) function and it works.
Thanks for your help.
(2,495 Views)
