NI TestStand
Apply Cluster Passing Changes using the API
Hi.
Does anyone know which API method to call to pragmatically apply cluster passing changes to a LabVIEW step? I would like to be able to make a LabVIEW program or a TestStand sequence which open up all sequences in a given folder structure and do the "Apply Cluster Passing Changes" for all relevant steps.
I have attached a small screen shot which illustrates how the function is performed in the editor.
Best regards
Jens Christian Andersen.
Best regards
CLA, CTA, CPI
(4,334 Views)
I believe it is called LabVIEWParameter.UpdateClusterMapping.  You can read about it in the help. I haven't tested it out though but that looks like the best description.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,294 Views)
Did you ever figure this out? /Is this part of the API now? I would like to do the same.
Kaitlin
Kaitlin N.
(2,115 Views)
