NI TestStand
Append 1d array to 1d array
Hi All,
I wonder if there is a way to append 1D array to another 1D array in TestStand other than by copying element by element in a loop?
Also if a part of array, say, Array_1 which has 10 element need its elements from 5 to 10 to be appended to another array at the bottom. currently I use loop. But I wonder other than looping each element of the array to another array is there any standard functions or TS APIs available like in LabVIEW?
JKV
(3,638 Views)
SetNumElements(Locals.Sum, (GetNumElements(Locals.Array1) + GetNumElements(Locals.Array2))), //Allocate Array For Sum
Locals.Sum = Locals.Array1 + Locals.Array2
It worked for me.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,630 Views)
Actually you don't even need the first line.  It still works.
To get a subset of an array you can copy the array over to a temporary array and then use the RemoveElements() function to remove the parts you don't want.  Then add that temporary array to your other array.
Hope this helps,
jigg
CTA, CLA
testeract.com
(3,629 Views)
@JKV999 wrote:
Hi All,
JKV
For the second question, in newer versions of TestStand (I think this feature was added in 2012), you can do the following:
Locals.newArray += Locals.Array_1[5..9] // NOTE: assuming array is 0-based so has elements 0-9
-Doug
(3,626 Views)
Hi Doug,
that is a nice feature.
Thanks for pointing out.
Regards
Juergen
--Signature--
NIWeek 2017: Standardized HIL Test Automation With TestStand
NIWeek 2016: Capturing ATE Requirements With Requirements Gateway
Feedback or kudos are welcome
(3,608 Views)
