08-25-2008 12:40 PM
During the course of our investigation, we discovered that a problem was introduced into the Database Logger in TestStand 4.1. TestStand 4.0 schemas should work perfectly in TestStand 4.1 when this is fixed. We appologize for the oversight and are working to correct it as soon as possible.
Please contact an engineer directly if you would like more information. When a fix is available I will post on this thread.
08-25-2008 01:02 PM
Hello Tom and Hans,
I just wanted to reiterate what Josh mentioned, which is once we have a fix your old schemas will work. Because of this I would recommend waiting to use those rather than customizing new ones. If you do have an immediate need to customize a new schema though let me know and I will assist as much as possible.
08-25-2008 06:22 PM
09-02-2008 02:20 PM
Josh,
Thanks for the response on this. I'd be happy to test any changes if needed, just email them to me.
Dave
09-04-2008 02:08 PM
Hi everyone,
Has there been any resolution to this problem? I'm commissioning a new production line next week and urgently require database logging in this project.
Alternatively, does the fix copying the TS4.0 database sequence work robustly as fix?
Tom
09-04-2008 02:54 PM
We have created a Patch for TestStand 4.1 to fix this isue with the Database Logging Result Filter Expression.
You can find the patch here: TestStand Development System 4.1 - Windows 2000/Vista x64/Vista x86/XP - Patch 123594: Fix for Datab...
This patch should fix all of the issues described in this forum thread. If it does not, please let me know.
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
