NI TestStand
Always save as previous version by default
I am using the latest TestStand version, and I need to edit Sequence files from other computers that are still using TestStand 2019.
Is there a way to configure my TestStand so that it always saves in Version 2019 without me having to manually click 'Save as previous version' every time?
Thank you
(366 Views)
Not aware of a default
yet you could create your own code to be called from the Tools Palette to save ta a default version using
PropertyObjectFile.WriteFile( writeFormat = WriteFileFormat_Current)
(336 Views)
How can this be done? I know how to call a sequence-file from the Tools menu.
But how to get a handle to the already opened file that needs to be saved in there?
Thx
(327 Views)
You can get the SequenceFile ref using
ThisContext.SelectedFile
(321 Views)
The sequence file that i call in tools menu has now one statement with tis text:
Locals.myRef = ThisContext.SelectedFile,
Locals.myRef.AsPropertyObjectFile.WriteFile(WriteFileFormat_TestStand45),
Locals.myRef.AsSequenceFile.Save("C:\\temp\\test.seq")
When executing it saves the currently opened sequence file as test.seq.
What do i have to change that i dont have to pass the path + file name to the Save() function and just save the file wit currentfilename at current location?
(318 Views)
Accepted by topic author OnlyOne
Locals.myRef.AsSequenceFile.Save("")
should save the file at the current location under the same name according to the help
(311 Views)
