NI TestStand
Adding VIs to sequence
I have a VI that all I want to do is have test stand execute it.
I Add Step->Action (using the LV adapter). Specify the module.
I run the sequence and I get the error:
An error occurred in the 'My Test' step of the 'MainSequence' sequence
in 'test.seq'.
LabVIEW : parameter Test Data not found in the VI's connector pane.
An error occurred accessing the LabVIEW ActiveX automation server.
Error Code: -18001
I have a test data indicator on the panel, I have a create test data
cluster in the diagram wired to the test data indicator.
If I specify module-> create the VI, I have no trouble...what is
causing this difficulty.
Anybody interested in being a compensated consult on this?
Brett
Sent via Deja.com http://www.deja.com/
Share what
you know. Learn what you don't.
(4,157 Views)
This question was answered by Paul Mueller.
You can find the answer to this question by searchin on "Adding VIs to sequence"
Anand Jain
http://www.ni.com/ask
(4,157 Views)
