01-12-2021 09:57 AM
Hi
I am looking for a solution, where I add visual limits to a statement step. I am able to integrate limits that either PASS / FAIL a step, but I would like the limits to be visual as well.
A picture of how it shows up in the report. Here the yellow label should represent Low and High limits.
The syntax I have used, to pass the step in 'Status Expression', but the limits are not visible in the report
I hope you are able to help,
Best regards, Andedam
01-13-2021 07:02 PM
Instead of a statement step consider using a none adapter step as a numeric limit step type. Then you can do the evaluation and get the information on the report correctly.
