Hi all,
I know that you cannot embed a custom UI into the step menus, but can you attach the existing Multiple Numeric Limits Limits UI to a custom step? The picture below shows what I would like.
I took this picture from a test step that works as I would like it to, it gives me a custom configuration window, as well as the multiple NLT windows. However, I created this step by combining my custom step type with a multiple numeric test step, which is fine except I don't want to run the numeric limit tests. I will be using the limits to run my own NLTs in a sequence called by the step. I have tried to find how to just disable the "automatic" numeric limit tests but have not had any luck yet.
The other way I have tried to achieve this is not "Combining" my step with the mNLT step but trying to insert the mNLT edit panels into a normal custom step types properties, but that does not seem to prompt TestStand to render the panels when I drag the step type into a test step.
Let me know if I can clarify anything, any help is appreciated.
Best,
jppb
