08-28-2012 04:23 AM
Hi all,
Is there a way to dynamically add Custom Types.ini file to the Types Palette from LabVIEW VI. I tried some of the approches like "Engine.DisplayStepTypeEditorEx" methods. But I actually want to make it fully automated without any prompts. I want to specify the ini file path in my vi and add it to the types palette when the VI is run from a TS Sequence.
Can anyone help me achieve this.
Thanks and Regards,
Nitz
Solved! Go to Solution.
08-28-2012 08:41 AM
You can just place the file in your TestStand public folder under: <TestStand Public Folder>\Components\TypePalettes. Then when TestStand opens again it will automatically show up. You can verify this by making a copy of MyTypes.ini (which is already in that folder) and renaming the copy. Then open TestStand and you will see both MyTypes.ini and the new one.
08-28-2012 09:23 AM - edited 08-28-2012 09:23 AM
Also, if you are using TestStand 2010 or newer you can programmatically update the type palettes using Engine.GetTypePaletteFileList and Engine.SetTypePaletteFileList. Use the Get method to get the existing type palettes, create a new array with those plus the new one you want to add and then call the Set method. See the API help of these methods for more details.
Hope this helps,
-Doug
09-03-2012 06:05 AM
Hi Jigg and Doug,
Thanks for your help.. Problem solved 🙂
Nitz
