NI TestStand
Add Items To HTML On-The-Fly Report Header
Is there an easy way to add items to the HTML report header when running the BatchModel.seq with On-The-Fly reporting?
CLA, CTA
(4,143 Views)
Some additional information:
I am looking to add different information to the Batch Header and the UUT Header.
CLA, CTA
(4,142 Views)
You're probably going to want to take a look at the ModifyReportHeader callback for the UUT header and the ModifyBatchReportHeader for the batch.
CTA, CLA, MTFBWY
(4,133 Views)
Thanks for the response.
I was able to use the ModifyBatchReportHeader callback.
However, The ModifyReportHeader callback does not occur with On-The-Fly reporting.  ModifyReportHeader and ModifyReportFooter Callbacks Not Called When the On-The-Fly Reporting Option is Enabled that explains how to enable this callback with OTF.
  • Are there were any "tricks" to add something to the header without major modification of the reportgen_html.seq file?
  • Is there any reason why this callback is disabled with On-The-Fly reporting?  What are the disadvantages of using the above article method?
Thanks!
CLA, CTA
(4,126 Views)
1. No
2. On the fly uses a processmodelpoststep callback to generate the report.
CTA, CLA, MTFBWY
(4,077 Views)
