05-13-2019 10:21 AM
Under the sequential model in the PreUUT callback, I can access the text report in RunState.Report.All.
In the batch model, that same variable in PreBatch just gets me the batch report text. How can I get the individual unit report text? Thanks.
Solved! Go to Solution.
05-14-2019 04:06 PM
Have you tried using the PreUUT callback? In the batch model, the PreUUT callback is used at the beginning of each socket.
05-14-2019 05:00 PM
Thanks for the suggestion.
There is one issue: the PreBatch runs before the PreUUT. So in order to see the results of the individuals in the current batch, I have to enter the next batch information first.
Can I force PreUUT to execute before PreBatch somehow?
05-14-2019 05:21 PM
Thanks shrupa123 for putting me on the right path.
It turns out that what I wanted was the PostUUT callback. First the PreBatch is executed, then the main sequence, and finally the individual UUT reports are accessible in the PostUUT.
