08-25-2008 10:22 AM
08-25-2008 03:03 PM
08-26-2008 04:28 PM
Hello John 242424,
Thank you for posting on the NI Discussion Forums. Attached is an example written in C#.NET 2008 which takes in a sequence file (chosen by the user) and then retrieves the names of its sequences, and steps within those sequences upon the click of another button. The key methods it uses are the SequenceFile.GetSequence( ) and Sequence.GetStep( ) methods. You will notice that Sequence.GetStep( ) currently only returns the steps in the Main step group. If you wish to find the steps in Setup and Cleanup, you will have to add this functionality.
09-04-2008 11:25 AM
Thanks Chris, I will look over your example.
