I want to programmatically access a sequence file's information (sub-steps & sub-sequences) prior to actually loading the sequence. I.e. I’m trying to make a stand alone GUI that allows me to select a sequence file and which sub sequence of that file I want to run at a later time. In C# I declare a sequence:NationalInstruments.TestStand.Interop.API.Sequence seq;But Sequence in an abstract class so I can’t directly create an instance of it. Ditto that for a NationalInstruments.TestStand.Interop.API.SequenceFile.Anyone know if this can be done and how to do so?
Thank you for posting on the NI Discussion Forums.Attached is an example written in C#.NET 2008 which takes in a sequence file (chosen by the user) and then retrieves the names of its sequences, and steps within those sequences upon the click of another button.The key methods it uses are the SequenceFile.GetSequence( ) and Sequence.GetStep( ) methods.You will notice that Sequence.GetStep( ) currently only returns the steps in the Main step group.If you wish to find the steps in Setup and Cleanup, you will have to add this functionality.
