NI TestStand
Access Numeric limit test- limit expression in vi
I am super new with Teststand
I have a numeric limit test step wherein the limits are multiplication of 2 floats. I would like to access the limits in VI for simulation purposes. I know that I can access the numeric value with GetValNumber property but I am unable to find the property for an expression like this 0.151*0.9NumericLimitTest.PNG
(3,321 Views)
I am not sure if the expression is available only the value.
(3,292 Views)
When IO try to read the value via property nodes, it gives me 0 as in the attachment. When I tried it with just a number (not a multiplication of 2 floats) as limit and it works fine then. I am not sure which property to use in the VIPrpoperty.PNG
(3,289 Views)
I see the same here.  I have not used expressions in limits before but I am guessing we get that behaviour because the limit expressions are not evaluated until after the code module.
(3,286 Views)
You need to use Step.Limits.LowExpr and HighExpr. There are Booleans Step.Limits.UseLowExpr and UseHighExpr to check if an expression is being used.
Regards
Ray Farmer
(3,248 Views)
