NI TestStand
ASAM XIL Steps
I am facing an error in ASAM XIL 'Create Framework' step. While initially loading test stand sequence there is no error. After closing and reloading the test stand sequence i am facing error. The error obtained is attached in the file.
Test stand version is 2021 SP1
ASAM XIL version is 1.5
Veri stand version is 2021 R2
(944 Views)
The "Create Framework" error in ASAM XIL might be due to incorrect framework library path, configuration file issues, or incompatible software versions. Check the library path, review configuration files, and consider reinstalling ASAM XIL and TestStand.
(897 Views)
Thankyou for your reply will surely try this out.
(885 Views)
