API to set SequenceFile password
I am trying to set password for sequence files during deployment in automated way.
Engine engine = new Engine();
SequenceFile seq = engine.GetSequenceFileEx(seqPath);
seq.??
I ve tried to find some documentation but no success so far.
(2,032 Views)
Accepted by topic author pawhan11
seq.AsPropertyObject.SetTypeDefinitionProtection(0x2, <password>)
https://zone.ni.com/reference/en-XX/help/370052AA-01/tsapiref/reftopics/propertyobject_settypedefini...
Hope this helps,
jigg
CTA, CLA
testeract.com
(2,009 Views)
Thanks, exactly what I was looking for.
(1,992 Views)
Script in c# works fine, next step is to create powershell script to do the same but I ca not instantiate Engine class:
$assembly = [System.Reflection.Assembly]::Load("NationalInstruments.TestStand.Interop.API, Version=19.0.0.172, Culture=neutral, PublicKeyToken=ad9244eb3b825cd8")
$engine = New-Object NationalInstruments.TestStand.Interop.API.Engine
The output is:
New-Object : A constructor was not found. Cannot find an appropriate constructor for type NationalInstruments.TestStand.Interop.API.Engine.
At line:2 char:11
I am not expert in powershell scripts so there might be something simple that I do not understand clearly.
(1,968 Views)
nevermind, it was related to 32 and 64 bit of powershell.
(1,961 Views)
