NI TestStand
2015 Teststand: LabVIEW is using a file with the same name as one of the destination files.
NI 2014 teststand
LAbview 2015
I had error message -19000 saying "LabVIEW is using a file with the same name as one of the destination files. National Instruments recommends that you close LabVIEW before you build a deployment."  to cause the deployment failure.d.PNGe .
Also attached failed log. Could you help? I don't see any hint to solve this issue.
Thank you in advance!
(2,920 Views)
I already close the LabVIEW and restart the teststand . tried a couple time. The problem still persists.
(2,917 Views)
This error sometimes appears when one of your built VIs has the same name as a default LabVIEW VI. You'll need to compare your VIs if there is one that has a name with this particular characteristic.
(2,886 Views)
Where can I find the default Labview Vi so that I can change their name instead of changing my project VI's name? Could you point me to that place? Or do you have a better way to solve if I find the name of the file causing the issue?
(2,883 Views)
