NI TestStand
-18001; And error occurred accessing the LabVIEW ActiveX automation server.
I installed a revised TS deployment, and got this error.
For other deployments, when this error occurred, there was a simple solution - change the Adapter in TestStand.
This time, if I change the Adapter, I cannot reload the test vi's in the test sequence, so that doesn't work.
Any help would be appreciated.
TS 4.2.1
LV 2010
(5,788 Views)
Jauron,
This knowledgebase article here: http://digital.ni.com/public.nsf/allkb/D577B50A1235A088862570FA004BDD63  seems to have a solution for the issue.
Kyle Mozdzyn
Applications Engineering
Kyle M.
(5,776 Views)
Even I have the same error. After following the steps, the error doesn't seem to be resolved.
(4,260 Views)
This link is broken and no indication of what it referenced. Is there an updated link available?
I'm getting this error and haven't found any other solutions that seems to be the cause. Hoping whatever this linked to might provide more into.
(3,505 Views)
