NI TestStand Idea Exchange
CyGa
Update step fields after using an Edit Step
Status: Declined
I'm declining this idea due to lack of community support.
When you use an edit step to modifiy the values contained in your step inputs/outputs, the fields are not updated with the new values. You have to close the step tree branch and reopen it to see the updated values. A good idea would be to refresh the step section after the execution of an edit step !
Update step val after Edit Step
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
11 Comments
CyGa
Typically the kind of advanced functions that is not widely used, but very important for those who are creating advanced coding in TS...
To bad that it is declined, because it is not an 'idea' it is more a 'request' for a bug fix... I'm sure that TS R&D team would agree with that...
